Edge Injector Tip Replacement
Glacier Diesel Power - feed pump users only
30 or 100 psi fuel gauge for 12 valve
Ive tried to find some sort of instructions on replacing the tips on my injectors but have had no luck. Can anyone enlighten me on how to do this? Id like to save my money if I can, they want $28 per injector to install and test them here. I have the Edge Stage 3 tips.
Installation is pretty simple. I put mine in a nice smooth vise(no cross hatches for grip) put injector in vise get nice and tight, get proper 12 point box wrench with a long shank for the most leverage, dont try to reef on it all at once, take firm taps with your hand to slowly break them loose, spin off head, tip will slide out(dont loose metering rod, will stay with each tip, new ones have them already)might have to clean a little to get them out, clean head up real good, install new tip in head and line up small pin on nozzle to injector body and make sure fuel hole is also in right location, install and tighten. Best idea to take and get popped when your done, i did mine and only one was off by 20 psi.
hope i explained it good enough, its pretty straight forward, just be clean and all will go smooth. DD
any carb cleaner or brakekleen will work, as far as shims you dont have to, thats why you have them pop tested, if one is off the will do it. dd
Ive never had my injectors out before, is it hard to do? My book says I need a special tool to remove them but I didnt think it was that difficult?
