Engine/Transmission (1998.5 - 2002) Edge Jammer Nozzles?
They work great! We actually install them on a core set of injectors for yo and then test them before we send them out. Then when you get them you send us back your injectors as cores. That way you know they are working correctly before you put them in your truck.
I've torn injectors apart before is there any particular reason why i couldn't do theese one's? What do you charge after i would get credited back for my injectors. Thanks
There isn't anything to complicated about taking them apart and putting them back together but they NEED TO BE tested before you put them in the truck and where we put them together for you we can test them before we send them out the door. We don't charge any additional for assembling them and testing, just the cost of the tips. There is a $100 core charge per injector IF they are not returned within 30 days of you receiving the injectors but it is not charged up front.
I think they work great. I bought them last year and had them swapped onto my stock injectors at a local diesel shop for ~$100. They tested them too.
-Deon
I have the stage 5 tips, the install is not bad at all, took just a few minutes maybe a half hour, they will definately need to be pop tested, cost me bout 60 bucks to have that done. I love them, they run great
Kevin
like 'em alot
Nothing to changing tips, but I needed special tools for the lines. Just take them to a local diesel shop, most will test
for free. :)
I am having a little "Bucking" problem towing, asked about that on another thread. :confused:
Recently put jammer nozzles in mine as well Awesome performace increase and smoke as well though. Injectors really work good but add a programmer to add more fuel that is when they really shine. First run i made with them in had 1/4 mile or better solid black streak but i like it nothing like smokin one of those fast and furious cars both at the light and their whole cab when they got the windows down. Won't be disapointed. Though I agree with these other guys it is a MUST they be calibrated Northwest fuel injection said they could be off as much as 12%-20% if not tested and that means less performance you pay that much for them might as well spend a few bucks more and make them right.
