Edge Juice I just called them
ATS COMMANDER/ Negative
Aftermarket box
I have not heard anything in a while on here so I just called edge and they said they still don't have a release date and that they don't know when it will be. I guess I will just have to try the TST I really wanted an edge but I also want more power. Any of you BETA testers out there if you could please tell me about the experience you have had with them so maybe I will wait a little longer.
Forget EDGE go with TST! I bet that their juice box wont make the power that the TST does. I have used the max settings on my TST and the only thing that doesnt like it is my clutch and tires. Dial your boost at mid 30's max and youll be fine.
I know they make a good quality product. I guess I am still leary I might get a code. If you buy the one w/gauges can you limit the boost that way? I have Dipricol's and probably would rather just watch them closely, instead of using the digital gauges. So does anyone have the box w/out the gauges and if so have you had any problems.
I have the tst box w/gauges. If you run the ground wire into the cab and ground it to the dash skeleton-no codes. Been running mine for about a week now with no codes. Not even the 0606,ecm .
Same here I moved the ground wire and shes perfect now. The only code I did get was the P0606 code, no biggie. As for the digital vs mechanical gauges I prefer the mechanicals but the backdown feature is nice for high end EGT's.
I think mark is working on that. Robertyoke was the one who found this. I personally can't understand it, but it seems to work.
