Edge Juice, no smoke??
Super B special ??
New to Diesels
Installed my new Edge Juice/w Attitude today, and wonder if I'm doing something wrong. Running on level 3, with the low boost fueling set on the highest (5) I am still getting little to no smoke. Is this correct??
Adam
level 3 wont really give you a lot of smoke, maybe a little puff in the beginning if you get on it hard but thats about it or at least what I get out of my truck... . 5 and 6(hot) will give you a decent amount of smoke but it clears up pretty good.
I have the HOT Juice, and it really only smokes on the new level 5 (level 6). Only a quick puff on the other settings. I actually prefer it! It's one reason I haven't picked up a Smarty yet. I want to be able to control the smoke.
I know that everyone thinks it's "cool" for tons of black smoke, and I do too, but only when I am playing around, not for daily driving.
I'm confused, what do you guys mean level 3 with setting 5? I understand the level part but how do I change the boost settings and the other settings to get it to run right.
you have a level three then for each level you have a sub level to control responsiveness or smoke levels. to get to the sub levels you push menu, juice config, then it will say something like low boost fueling, you should be able to enter into each level individually and change the sub level.
I have found that running the truck on level 3, it does not really matter what I set the low boost fueling at, it performs about the same, do you guys feel that way?
You aren't going to get much if any smoke with the comp/juice especially on the lower settings. When my brother's truck just had the comp on it the sub settings really didn't do much when you got above 3. The truck felt a little stronger but 5x1 and 5x5 was about the same. We had stacks so we wanted to see smoke out of them, so we added injectors. If you add injectors, you will realize what the sub settings are for. Injectors will make the juice come alive.
