Engine/Transmission (1998.5 - 2002) Edge Juice unlock code?
Engine/Transmission (1998.5 - 2002) smarty idle?
Engine/Transmission (1998.5 - 2002) boost fooler?
I know a while back that Edge had some sort of a special offer to TDR members on getting the hot codes for their performance boxes. Is this deal still around?
Thanks!
-Chuck
To the best of my knowledge it is... . not sure what you need to do. Probably call edge or someone on here will chime in and tell you what it is. Just tell them you are a TDR member.
Hmm, does it just add fueling and lack of high RPM defueling on all settings, or just level 6? Does it do anything for the lower settings?
-Chuck
I would still think that someone would be able to give you the unlock code..... they should be the same on all units, but maybe not.
A buddy of mine got the hot unlock code. It's based on the Juice serial number. I've tried to "crack" the code and get to work on mine, but have had no luck so far...
His serial number was 161 and the unlock code was 6d99... if that helps anyone.
