I think blue chip or someone makes a replacement cap for the vp44. it has a external screw correctly located over the right connection inside. Replace the cover, turn in the screw, attach wire on outside. I think this is the safest way to tap a pump. You can always put on the old cover on to undo it. It seems easy to install once the APPS is out of the way.
