The PS66 thread got me thinking about compressor trim (well, turbine trim too, but there are no turbine maps that I have seen).
The way I think of compressor trim is basically the "slant" of the angle at the edge of the compressor. Since it's inducer^2/Exducer^2*100, that's the best way I can illustrate it. Is this correct? Cliff?
So, when you go to a higher trim wheel (like from say a 40 trim to a super 60), what effect does that have on the map?
Our CTDs seem to need a higher PR than a gasser engine would-- blame the crappy airflow in the heads and anemic stock cam.
Is a Higher trim more conducive to a higher PR or a lower PR?
Is it correct to say that optimizing a compressor for higher PR results in a center efficiency island that is both 1) smaller and 2) lower in overall efficiency?
It appears that a lower trim can make the map fatter and more efficient, but you lose PR and peak airflow.
I'm looking at this map:
It appears that the surge line moves to the right with the bigger, lower trim compressor.
Yet the smaller wheel (56 trim) appears to have a fatter middle section, at the cost of peak airflow and PR.
Doesn't the GT42 overall appear to be a potentially good candidate for a CTD??
Just curious. I'm educating myself on this, and getting more questions than answers. (like why is everyone using Holset or Schwitzer chargers and totally ignoring Garrett/Turbonetics?)
Justin
Justin
