At work a couple days ago I was running one of our instrumented dyno engines, and had a few hours to play around. I can't reveal the engine make (protected by privacy agreement with the supplier), but it is an inline 6-cylinder, turbocharged and intercooled diesel... and is of the same basic configuration as the engines that we have in our 3rd Gen trucks. Anyway, with the ever-growing selection of electronic boxes to add to our trucks (including TST's timing advance feature now), I took the opportunity to see what effect changing the timing advance would have on some other parameters...
The test was conducted at 1800 rpm, with the engine being fed by conditioned air at 79° F and 54. 8% relative humidity. Fuel was 2007 certification fuel, and the fueling duration was held constant at 25°.
Sorry for the small size, but I think it's still readable.
The yellow band indicates the point at which peak torque occured (12°).
The blue band indicates the point of best "bsfc" (fuel efficiency) occuring at 19° advance.
The pink band at 9° advance yielded the lowest peak in-cylinder pressure rise.
I know there are a lot of differences between our engines based on the pressure boxes, timing boxes, turbos, intake and exhaust mods, etc. that we've chosen, but for a representative case like this, here are some general observations:
At this engine speed, advancing the timing increases the torque output until about 12°, after which it tapers off. Based on "bsfc", fuel economy gains can be seen by advancing the timing to a range between 19° and 21°. Note however, that the "peak pressure rise" is nearly doubled here compared to more moderate timings. The "peak pressure rise" is how fast the pressure is increasing in the cylinder during a combustion event. The units are pressure rise (in bar) per degree of crank revolution. Lower values here tend towards engine longevity, while values approaching 8 - 10 bar/deg can cause severe knocking. "BSFC" is brake specific fuel consumption, and is basically a rating of how much fuel the engine is using to produce a given horsepower (lower values equivilate to better fuel efficiency).
Also interesting is that as timing was advanced, the turbo temperature, boost pressure, and fuel injection pressure all decreased.
