Most dynos use the SAE correction, which is designed for normally aspirated engines. When altitude gets high, the correcting factor is too big for us. For a rough estimate, look at the uncorrected and corrected numbers and go maybe a fourth to halfway in between, depending on altitude. the higher the altitude, the more exaggerated the correction vs. what it should be.
