Has anybody got a source for a egr cleaning kit and a egr cooler filter kit as well?? The truck is runing now after a new air filter and air filter housing cleaning and all connections sprayed with senor cleaner and the batterys both were load tested and both had coroaded terminals that were cleaned by me personally so that low voltage reading has vanhised but am wondering now if the egr will stick next time it goes into regen, i need to clean it and spray it down and the egr cooler filter as well just to get used to this problem. This truck is a 6 speed manual 07 with 6. 7 and 112k miles on it and has been in the shop several several time and has been reflashed, had the egr valve replaced once, the egr cooler filer replaced at 69k something and was doing fine until it seemed to lose power and cel came on, it acts like the dpf is clogged to me. We drove it home from a shop and it was running great but still has cel we can not erase with the autozone scanner. Anybody got any ideas how to check to see if the dpf is clogged or the o2 senor is faulty?? I am thinking first time the truck goes back into regen the egr might stick again and leave us stranded. No dealer around here anymore so i am going to get some help and clean out the egr and replace the egr cooler filter as well just to make sure. The dpf was $2200 dollars, the egr cleaning is $600 and not including labor on the dpf either, the egr valve was $600 when we checked for price and availabitly at Brown Dodge in Devine Texas where truck was purcased. If i can get it running enuff to take to dealer 4 hour drive can hey check the dpf to see if it is cracked or plugged and how much will that cost??
We checked a Anothys Plantet Pickup and a Smarty or Hand S delete kit with controller and all new exhaust is around $2500, just the dpf is $2200 plus labor, add in a new egr valve $600, lablor, egr filter kit plus labor, and still the sorry performing system on your truck to crash again at any time it looks like i am going to remove all of this junk and replace it with controller and complete egr delte kit and all new exhaust and have a good truck again, something this truck has not been in a long long time. Is there a newer code for the 1th year 6. 7 out again?? This truck was refleashed 4 times and is susposed to have latest one in it and has the code on the rad suport with the sticker? I wish i could just get it fixed stock and not go bankrupt trying to get it runninglol I am driving the old 2001 with edge attitude, air filter, exhaust upgrade and its so much a better truck except for the exaust brakelol
