EGR and DPF delete with Smarty ?
Used truck caught my eye
Leaks?
Brother in law owns '07. 5 6. 7 and told me "I don't care what it costs, i want an EGR and straight pipe ... "
1) Have contacted a vendor and will order S-67ME as soon as we can collect info on a total package ...
2) Have read Smarty's EGR delete html ... got it ...
my questions are;
1)What is the most well made complete kit for EGR delete?
2) Is there a complete (turbo to tip) DPF delete exhaust out there somewhere?
3) What do you do with the two lines into the DPF?
Thanks in advance, any advice or links would be appreciated.
There are several manufactures that sell the 5"TBE system. I am using the 5" TBE from MBRP with a 6" tip.
As far as the two hose from the differential pressure switch to the DPF, I removed the hose (left them on the DPF when stored) and left the differential switch mounted on the transmission.
I installed block off plates for the EGR valve and tube assembly. I left the EGR cooler installed on my truck.
Follow the information from Smarty on the ME version and you should be good.
Jim
delete
check out H&S tuners web, the have good stuff . will sell a kit where you dont have to worry about sensors. There pipes dont even have the bungs in them . not needed
I have H&S too. . It's great, 20. 9 mpg on the OH, and nice power. The truck does seem to run out of fuel when it's pinned. May have to get a FASS. .
