The biggest killer is not properly bleeding the cooler when adding/filling coolant. The lack of coolant burns them up in a hurry.
EB's dealer should have had this test a year or two ago. I think he was one of the first trucks to be diagnosed as a head gasket when it was the cooler. The lifespan is very long as long as it stays full of coolant. The biggest killer is not properly bleeding the cooler when adding/filling coolant. The lack of coolant burns them up in a hurry.
The following is from the service manual (Filling - Diesel Engine):
2. 6. 7L Only. Remove vent fitting.
NOTE: The diesel engine is equipped with two one-way check valves (jiggle pins). The check valves are used as a servicing feature and will vent air when the system is being filled. Water pressure (or flow) will hold the valves closed.
Where is the 'vent fitting' on the 6. 7L? Is there only one? Do the 2 ea. check valves go to the same vent port? I've searched the service manual but can't find it.
