2nd Gen Non-Engine/Transmission EGT probe drill bit size
2nd Gen Non-Engine/Transmission Clunking noise
Engine/Transmission (1998.5 - 2002) Edge Comp gone south?
What size drill bit do i need to drill the hole for a autometer 3344 egt? And what size tap? It is a sport comp gauge. I am drilling tha exhaust manifold
Double check, but my Autometer EGT guage uses 1/8" NPT threads. I bought a 1/8" NPT tap at Homer D. for a few dollars. It came with the right size drill bit.
Have fun
Dave
If you are about to install your probe, I have always had better luck going with the 1/4" NPT size and then using a brass fitting to reduce to the 1/8" NPT size of the probe. The manifold is cast and the probe is steel, after they have been run and gotten heated they do not want to separate, even if anti-seize is applied. So the brass fitting separates the two, and makes re-placement it it is ever needed, much easier. Also for the 1/4" tap you will need to drill a 7/16" hole. Good luck
