EGT Question Can a stock truck while pulling a load generate excessive/dangerous EGTs? My thinking goes like this, if the truck is stock, it should be engineered to pull a "reasonable" load without generating high enough EGTs that could damage the engine. Right? I have the gauges on my current truck, but didn't on my '93. Now that I know how EGTs react to different driving situations, I am sure that I have been pulling loads while exceeding 1200 degrees, for extended periods of time, like 20 minutes. But I have never had an engine problem. So I am thinking that our trucks left stock can't really hurt themselves. Otherwise, these trucks wouldn't have the reliability record that they do. What do you think?
Also, I was pulling a load up a 6% grade for about 10 miles (before I had my EGT gauge working) and heard the fan kick on when the stock temp gauge needle would reach 240 degrees(Edit: I meant 190
), or right in the middle. Does the fan help EGT's at all? What temp does the fan kick on at and what is the equivelent EGT temp. I have to imagine that if the fan kicks on, the EGTs have to be pretty high. Is there any correlation between the two?
