Whats the highest continuous EGT you would want to see while towing?
I've heard 1250 is max while towing. From what your saying sounds a little high.
Stock motor, 04. 5-07, will run 1450° and do it all day, add some timing and that number drops fast.
Post turbo readings are really pretty useless, they very 200-500° from manifold temps, and based on the poor exhaust flow of the HE351 tell only a part of the story. Wagering your EGT's on a post-turbo pyro is far riskier than a pyro failing and eating a turbo, not to mention a turbo is far cheaper than a motor.
Post turbo is not useless, they work fine. If someone wants pre, thats totally fine, any temp gauge is a good thing. I have and will wager my Cummins powered trucks on post readings.
The problem with post-turbo is the rpm/boost dictates the temp drop across the turbine, and it's never constant.
On a stock motor it would be fine considering you would get a feel for what means what and you know it won't melt, but anything modified doesn't tell you enough.
When I had my old '01 HO/six speed with Bosch RV275 injectors pulling a grade with a trailer on I could simply floor the accelerator pedal for a second and instantaneously peg my EGT gauge at 1600*. I would back out of it as quick as I floored the pedal and ease it back to 1300*.
A post turbo gauge would never see that instant rise to 1600*.
If you would have had a boost fooler and boost elbow you could have floored it and kept it there. The RV's are not a good stand alone mod. If you tow, there is no reason to build anymore power then you can use. All my trucks are modified and I can stand on the go peddle as long as I keep the RPM under 2100/2200 and no lower than 1700.
Back in the day with big trucks and before oil cooled pistons there were guys that could just tear me up on a short steep hill but give me a few miles and they were history. The norm then was 1200* pre and 900* post and ya better not push it either.
Nick
Exactly... Like I previously stated, I ran my pyro for a year or two thru a WIDE variety of conditions with the engine is stock trim before adding the Jr... I can say that my overall EGT is significantly lower with the Jr. than in stock form in any condition... . stop and go, unloaded, overloaded, 95 MPH on Interstate. . etc... I completely agree, stock and/or lightly modified (jr) the POST is a very useful tool...
Cerb/AH/Harvey... Yes, on larger engines, and heavily modded engines, pre-turbo is the only way to accurately monitor and trend what is going on inside the cylinders...
Actually, your single pre-turbo thermocouple is what is useless in that situation, you should have each exhaust port individually tapped and a thermocouple installed in each port. Connect it to a digital exhaust temperature scanner that way each cylinder is monitored.
In the industry I work in, cylinder port temps. are critical... Natural Gas and Diesel applications... I'm talking real diesels with real horsepower though... not little OTR engines...
:-laf:-laf:-laf
