2014 Ram 2500 Limited 4wd 6.7 Cummins - running Bully Dog GTX as a monitor only - 76k miles
EVIC shows a message of "Exhaust System Service Required - See Dealer". At normal operating temperature,
EGT-2 (DOC Outlet Temp) shows either 40* or 5928*, both of which I believe are total bogus. All other EGT temps are within normal ranges.
Monitor shows following codes:
P2033 - Exhaust Gas Temperature Sensor Circuit High Bank 1 Sensor 2
P24A0 - Closed Loop Particulate Filter Regeneration Control at Limit - Temperature Too Low
I assume this means EGT sensor is bad, but dealership says may be a clogged DPF filter. Unfortunately, dealership is now closed due to COVID-19.
Looking for suggestions and/or recommendations.
