EGT/thermcoupler install-what sealent??
Intake sensor/cleaning
What is the exact difference between 03/04 and 04.5/05 engines?
When installing the EGT/Thermocoupler, for your EGT guage---what if any sealer,lube,or noseze is used??? Also what is used on the BOOST fitting??
thanks Rocky in KC
Use a never sieze type thread lube on the egt fitting and teflon tape on the boost fitting. The boost fitting probably should have an inert material because of the different sensors in the air stream. bg
