RE: EGT Too High (LONG)
In have experienced the same thing - EGT's going out of control. Using TST #8, and Transgo Shift kit. EGT's easily exceed 1500 degrees only while towing in O/D. Great power but when O/D kicks in on even small grades the EGT's skyrocket. The only thing that I have noticed is that when my boost (stock turbo) exceeds 32 PSI in O/D (around 2000+ RPM's) is when the EGT's rise. If I can manage to hold throttle to keep boost at 32 PSI I get the power but EGT's are at 1250. Yes the water temp also increases I can hear the annoying radiator fan cycling as well. I am at almost maxing GCVW (17,500) when my normal towing setup was weighed last year. I seem to be driving at 2300+ RPM's everytime I tow. I get 9 mpg when towing, 12 mpg unloaded.
Loosing the cat dropped the temps slightly
Maybe 100 degrees, but the exhaust smell that is now no longer filtered is terrible. Since the cat was removed, I also now have black smoke sputtering out of the exhaust when idling . I also spoke with Mark at TST and at his advise re-checked all turbine hoses/clamps and the charge cooler. He said that the #8 plate shouldn't run this hot.
I have a 3" exhaust. (Using Amsoil airfilter stock box) Timing was increased to 15. 5. Rear Diff 4. 10
Looking to increase turbine housing and try a 4 " exhaust. After this I am out of ideas. Sometimes I think of selling the truck to get a 24 Valve and an Edge EZ. to ease this PITA problem.
What about getting an ATS transmission w/triplelock T/C and increasing hp? Will this allow me to tow at lower rpm's, control boost, and thus lower EGT's while not losing the power?
Maybe plate is too far forward and I need to move it back. I may have just been using more power (fuel) then the plate was intended to provide.
