This is my 3rd CTD the first I’m Bombing and the first one I’ve installed an EGT gage in. Now when I’m towing a 6% grade with my 6500lb 5th wheel, I had to back off and down shift, I’m getting into the 1100 range. The next trip same pass without the trailer I had the same issue. This is ridicules I’ve heard guys on here going up the same pass (Cajon pass) at 60 mph pulling 15000 lbs passing car.
Is my high EGT due to the stock 3” no muffler exhaust or is the power puck not that great? I was in Flagstaff AZ last month and the truck ran awful 5000ft. It seams the truck comes alive after 2000rpm. I can brake the tires loose going into 3rd and there lots of smoke, but this is of little use when you’re towing, up and down hills.
Thanks in advance.
Thanks in advance.
