That sounds good. I will remove my injectors and do a compression test or whatever. i'll have to read up on that. As for setting my wastegate... what do you think of this? I am thinking of "T"ing into the wastegate actuator line inbetween the AFC and the wastegate and putting a needle vavle in the cab with and open ended line running out the needle vavle back outside into the engine compartment. Then simply replace the TST elbow by putting a straight elbow w/out an allen head on the back of the afc. Then I could determine how much boost signal goes to the wastegate actuator by bleeding it with the needle valve from in the cab and set my wastegate to where egt's are reduced the most, spool up is good, power best... ...
Think this will work?
Jamie
Jamie
