Fuel economy...
dvaughan -
I'm going to have to respectfully disagree with some of your reply.
Placement of maximum power has been changed on the 24 valve to encourage operation in the most fuel efficient engine speed range.
Its true that the best performance range can be tuned somewhat, but the primary reason for the most efficient rpm being located where it is, is due to the dynamics of 24V vs. 12V engine.
For on highway cruising and no load, maintain 2000-2200 rpm for best fuel economy.
I do agree with you that the engine is using fuel more efficiently at this rpm range. But that does not mean that you get the best fuel economy cruising at this rpm. Here's a basic example, these numbers are made up, but are relevant.
Let's say the engine is running at 2,200 rpm for a mile on level ground in 6th gear at 75 mph. During that mile, the engine consumes 210 milliliters (mL) of fuel. Of those 210 mL, 45% is used to drive the piston. The rest is wasted.
Let's say the same engine is running at 1,800 rpm for a mile on level ground in 6th gear at 65 mph. During that mile it consumes 172 mL of fuel. Of those 172 mL, 40% is used to drive the piston. The rest is wasted.
In this scenario, the engine was more fuel efficient at 2,200 rpm (45% versus 40%). But the fact is, it used more fuel at 2,200 rpm to go that mile than it did at 1,800 rpm ( 210 mL versus 172 mL).
Therefore it is more fuel economic to drive the slower speed.
- JyRO
