Stop right there... .
The 100° difference you are seeing is about right for those circumstances.
I have my pyro post-turbo, and I may move it. But, the difference between the two readings is not as great as people assume under constant states.
The problem is that the variance in post- and pre- reading is that is is NOT constant.
At the limits, you might have 275° of difference. At cruising, you might have only 100° difference or less. At idle, it will be even less.
The thing is that that higher the temp is, the faster that heat will bleed off. The temp difference between the hot part and the cold part affects the rate of energy transfer between them.
What I am saying is that the difference between pre- and post is greater the higher the temp goes.
I might move my probe to pre-, just because it responds faster, not necessarily much more accurately.
HOHN
