The latest design of pacbrake allows the brake to hold the back pressure to a lower rpm... this is important for longer braking... .
When the brake is located a distance from the turbo and the brake comes on... the tube has to fill with pressure before the system works... .
Think of the exhaust pipe as the tank on a compressor... you need 60 psi for great exhaust braking... . if the space in the tube is 5 or 8 times larger then the space of the turbo mounted brake its going to take about 5 to 8 times longer to reach the magic 60 psi...
Why 60 psi... . any pressure above that on the cummins 5. 9 or 6. 7 would open an exhaust valve at the wrong time and there might be piston valve contact... . that's one reason why we suggest that unless you know your p's and q's you don't try to adjust the max pressure of an exhaust brake at home... BTW - each engine class has a different setting based on the engine builder... . as an example some Cat engines have such weak exhaust valves that exhaust brakes and engine brakes don't work well enought to warrent their expense... .
Both the Jacobs and Pac units have proven to surive well in the heat around the turbo... . Remember also that only Jacobs and Pac are approved by the engine builders for other engines and applications where they can be factory installed..... Cummins, Cat, Mercedes Benz, Hino, etc..... Also because of their programs with the engine builders they get direct contact to engine engineers where I can only assume BD, US Gear, and the others don't have access to... .
These are just a few of the compelling reasons to stay with the top names.....
