After much investigation and plenty of walks through the local junk yards, I finally installed electric fans. here's my last post on this topic: https://www.turbodieselregister.com/forums/showthread.php?threadid=94194
They came from 2 1988 Buick Park Avenues and each have a diameter of 18". It is a tight fit but after some fabrication and "modification" of the shroud they will fit. Right now only 1 is wired as I'm waiting for another relay to come in at Radio Shack. The current set up uses a toggle switch but that will change as soon as I find a place to mount a coolant temp switch - Please post any ideas. Also I thought about tieing in to the AC clutch but I'm not sure I want the fan to cycle on & off with the clutch. I could use some suggestions to wire that too.
Paul
Paul
