It doesnt have to be confusing nor involved but yes you're right in that everyone has an opinion. Either way, there's things you need to do correctly otherwise you can affect the performance and reliability of the gauge.
It probably way more than you want to do but this is what I did..... I got a tapped 90* barb fitting for my new lines and ran it off the bottom outlet of the fuel filter housing. You want your gauge to be post the fuel filter. Then using all JIC fittings, I ran a -3 JIC fitting stainless steel braided line from that 90* up to a tee fitting on the firewall. About 5 feet. After the fitting I installed a dedicated snubber to another -3 JIC fitting stainless steel braided line which runs up to the gauge. About another 5 feet. I had ISSPRO install a snubber orifice in their mechanical FP gauge. Here's the important part most people forget or dont think about. In that tee fitting I used the 3rd port to re-install the schrader valve test fitting so I can confirm and compare my in-cab gauge with the test gauge for accuracy and diagnostics if needed. How does anyone know if the gauge they just installed is even accurate?
You sound like you still have the factory fuel lines so you shouldn't need to go through half of what I did. If you have no plans to upgrade the fuel lines then you still have the schrader test ports in place and all you should need is a
tapped banjo or
tapped banjo. You can use hardware store parts to fit a regular brass 1/8 NPT fitting into the banjo. If you're going to go with a mechanical gauge then the type of hose you choose to use will dictate the fitting type. From the tapped banjo you should install a dedicated
snubber and run all lines from the snubber.
If you choose to go with an electric gauge (which is totally fine and the more common route) then you still need the tapped banjo and snubber but you can run the gauge sender off the snubber and then the wires up to the cab. Much less work.
Either way, the snubbers are necessary otherwise the hydrodynamic fluid pulses from the VP will eventually beat the electrical sender or the mechanical gauge to the point where they're no longer accurate or working. So do NOT mount it directly on the VP as thats way too close to the pulses, you can use a hardware store needle valve as a snubber but I dont care for the potential inaccuracy, and no hydraulic lines or grease gun lines will act as an insulating snubber for the pulses. Those lines are rated in the hundreds and even thousands of pounds whereas the pulses and fuel pressures are only between 10-20 psi. Not enough to even flex those high pressure lines.....
Now all you have to worry about is gauge brand. Just dont get Glowshift as they're prone to inaccuracy and reliability problems. Rather stay with quality like Autometer, ISSPRO, or many other name brands.
