Electrical boost pressure gauge?
Vandal got my truck
injectors and plates
Dumb question:
I'm going to install a boost gauge, and I want as much information as I can get before I order parts and such. Each boost gauge I've found has been listed under the "mechanical gauge" section of the manufacturers' catalogs and web sites. This means that I have to run a pressurized hose into the back of the gauge, right? #ad
If so, has anyone had problems doing this with a pillar-style gauge mount? Does anyone make an electrical air pressure guage so I can leave the sender under the hood?
--J
John Miller
'01 2500 Quad Cab, ETC-DDX, SLT, Long Bed 4X4, Tow, Travel, 3. 54, Camper spl, Forest Green, Line-X
bed liner, silencer ring removed
[This message has been edited by JJMiller (edited 03-19-2001). ]
All of the Boost Gauges that I know of use small diameter tubing directly to the gauge. Mine is on the A pillar and has worked fine for a couple of years. I havn't heard of any with trouble.
98. 5 2500 QC LB 4x4 5spd, white. BFG 285x75x16
Cummins 24v w/ TST PowerMAX w/EGT and Boost gauges on A-Pillar. VanAaken CPC. K&N In the factory air box. Stock Injectors, Stock Exhaust (Geno's Muffler Eliminator). Re-routed breather stink tube, 2WD-low kit, SnugTop, JJ Stainless Running boards, Tow Hooks, Bushwacker Street Flares, and a Cup Smoothie.
83,000 miles (1/10/01)
The SPA digital gauges have an electric boost signal back to the guage.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S SPA Boost/EGT Everything but leather NRA Member Great Lakes TDR Member
