Okay, I've been working on this project on how to wire in some reverse lights using a SPDT switch using both on terminals as power inputs and the middle pole as the accessory being powered. I'm using a fuse tap for power for the relay when the switch is in one position. I found that both sides of the reverse light fuse are above ground potential all the time. one side has 1. 5 volts and the other side has 12. 5 volts or so. Either side of the fust when I put the fuse tap on is switching on the relay whether the reverse lights are on or not. Why would both blades be above ground potential all the time? I understand that one of them needs to be.
