OK, I have seen threads on this but never found a cure. I just started having this problem 3 days ago.
Everything worked great, BUT I filled up with fuel, started the truck to leave the pump and noticed the:
Parking Brake
Water in fuel
Wait to start
Lights were all on.
Make a long story short,
When I hit the power window switch, these lights come on. ( windows will not work)
Play with the A/C , heater controls they go off and on with the pressing and depressing of certain buttons.
Blower motor does not blow at all unless I am running 75 or 80 mph. (charging system is spun up at that point)
When I pull up to pay a toll , when sitting there with the brake on, after a couple second all 3 lights come on slowly, and turn off as soon as I let off brake and accelerate.
I installed a new battery today. (1000 CA just wanted a bigger battery)
Cleaned both battery terminals and all hardware, including other wires ran to terminals.
Checked and cleaned Ground to body, Ground to block, ground under the dash, connections.
I really need my heater to work Hebron, IN. 10 to 20 degrees the last couple mournings!!
Any advice would be very helpful and appreciated!!!
Parking Brake
Water in fuel
Wait to start
Lights were all on.
