Alright, I've searched about as much as I can, and now I'm posting my own thread. The truck with start and run fine, but will only charge when I am sitting completely still. I believe that there is an intermittent ground somewhere, but I can't find it, and my Dad is in MO with my FSM, so I can't track down all the grounds to check them. I checked my ground under the dash, the one on the core support, and of course my negative ground cable. The lights will pulsate like a disco ball when I am running down the road, but work fine when I am sitting still. I have put an external regulator in and have bypassed the PCM in regards to the alternator, but everything else is run through the PCM. I'm about at my wits end chasing wires all over the place.
Any help or insight is greatly appreciated.
Thanks,
James
Ps truck won't shut off with the ignition switch either, I have to pull the pump wire shut her down
Thanks,
James
