I Just Received A White Knight Back Up Light Assembly. I Measured The Current Output Of The Knight Assembly And It Was 8. 0 Amps... . if I Hook This Unit Into My Trailer Wiring Assembly (factory Provided) When I Use The Standard Back Up Lights Plus The White Knight. . im Wondering If I Will Blow A Fuse In The Truck????. i'm Sure Some Of You Have Done This Installation But I Have No Idea What Amperage That Circuit Is Fused At???? Any Help ????thanks Doc Ps,,the White Knight Has A 12 Volt Fused (red) Leed That I Can Run All The Way To The Battery, But The Wiring Instructions Advise Using The 7 Pin Receptical... .
