Dodge Ram
Referring to 24V Turbo Diesel 1999 Model Year Wiring diagram for ECM part # (3942336) Bulletin # 3666480
Accelerator Pedal Idle Validation Circuit Resistance for on and off - idle states
Maximum closed circuit resistance <125 ohms
Minimum open circuit resistance >1 k ohms
between supply and return wires 2000 to 3000 ohms
between supply and signal wires (released pedal) 1500 to 3000 ohms
between supply and signal wires (depressed pedal) 200 to 1500 ohms
NOTE: released resistant - depressed resistance must be 1000 ohms
Can you turn on a transistor with this kind of excessively high resistance?
