Archived Electronics
Archived 98 24V wont' start.
Archived how do I turn off check engine light?
Dodge Ram
Referring to 24V Turbo Diesel 1999 Model Year Wiring diagram for ECM part # (3942336) Bulletin # 3666480
Accelerator Pedal Idle Validation Circuit Resistance for on and off - idle states
Maximum closed circuit resistance <125 ohms
Minimum open circuit resistance >1 k ohms
between supply and return wires 2000 to 3000 ohms
between supply and signal wires (released pedal) 1500 to 3000 ohms
between supply and signal wires (depressed pedal) 200 to 1500 ohms
NOTE: released resistant - depressed resistance must be 1000 ohms
Can you turn on a transistor with this kind of excessively high resistance?:confused: :mad:
OH yeah, bi-polar (PNP or NPN) transistors can be turned on with resistances higher than 100K ohms. Depends on the hfe, beta (gain) of the transistor and how much collector current is being controlled. Divide the collector current by the gain factor and that is the required base drive current. As long as the voltage is high enough / resistance low enough to force more current thru the base junction than the value obtained by the equation, then the transistor will turn 'on'.
FETs (field effect transistor) have input impedances measured in meg-ohms. They are voltage controlled, not current driven.
