After reading all the answers I received from my last post I had decided to remove the factory brake controller on my 2010 2500 Diesel and replace it with a after market controller. I took my truck to Crenwelge Dodge in Kerrville, Texas and they told me that the factory controller could not be removed from the software! They said that because the truck was built with the controller in it it would have to be left there. This does not make sense to me so maybe someone out there could enlighten me as to what can be done to solve my problem.
The factory controller just applies a small amount of braking, hardly noticeable no matter where the gain is set! If I pull the break away pin, the brakes lock up tight. I have checked the grounds for proper connection and connectivity and the controller is getting 12v from the feed. I called the Chrysler customer hot line and they said if the dealer said the controller could not be removed then it couldn't!
HELP!!
Ken
HELP!!
Ken
