2nd Gen Non-Engine/Transmission emergency flashers & outside termperature reading
I did a search and couldn't find my answers, on my 01' QC 4x4
my turn signals work but not my emergency flashers, is there just the one flasher on an 01' by the drivers door or is there another flasher somewhere? if I turn the emergency flasher switch on (they don't work) then my turn signals don't work either? any ideas? should I try a new flasher if there is only one?
I need to get into my overhead console to change a map light bulb, ever since I've had this truck the outside temp has shown as -40, is there any way to reset this or any ideas?
thanks in advance for any help!
I believe there is only 1 flasher in the junction block on the side of the dash. There are 2 fuses however. Fuse 10 in the junction block and fuse 4 in the PDC under the hood.
The -40* temp reading means you have an open circuit in the sensor or sensor wiring.
Thanks, I'll look a the fuses today, I don't know about the sensor wiring, I may just let that go, I have no idea where the sensor is.
