Several of us are running the Energy Suspension bump stops on our overload springs with great results. In fact I have not heard of one failing.
I emailed Energy Suspension about getting a set for my brothers F250, here is there answer.
No I have not been asked about this application.
Energy Suspension does not recommend using their bump stops for the application on your Dodge. I am impressed that it is working well for you.
E. S. bump stops are intended for occasional use only, not to carry a load, as you are expecting them to do.
They are named 'Bump Stops' because they are only expected to touch or bump into the frame or control arm occasionally.
Consistent compression loads on polyurethane bushings with the durometer of our bump stops, will usually lead to premature failure.
The difference could be the choice of material for the 9. 9109 that you are using on the Dodge. It is probably made of the 95A durometer material. This was one of the first bump stops that E. S. developed 25 years ago, when the choice of material was limited. The newer bump stops seem to be made of softer material, as they should be, for there intended use.
The Airlift company offered a part that they called an 'Air Cell'. It was a bump stop type of part that they offered for use on Chevrolet 1 ton, 4 wheel drive trucks with torsion bar front suspension and a snow plow on the front end. This part was intended for heavy loads. The cost is $135. 20 pair.
Part Number: 52110
Air Cell; Torsion Bar Load Assist; No Drill; Installation Time - 1 Hour Or Less;
Features and Benefits
§ Prevents Suspension Damage
§ Reduces Bounce And Sway
§ Resistant To Most Chemicals
§ Cold Weather Proven
§ Excellent Abrasion Resistance
§ High Tensile Strength
§ No Maintenance Required
§ One Year Limited Warranty
Part Number: 52110
