Archived eng trouble code P1755
Archived 2007.5 6.7L Headlight Issue
Archived Truck won't start
I have a P1755 trouble code, should I be concerned? Truck runs great, auto trans shifts great, stock guages all indicate normal readings and MPG has not changed. Check eng lite is off. Truck has been serviced according to specs at the dealer.
I just replaced the 7 year old stock batterys that failed, not sure if that could be related... Can I clear the code without the dealers $90 charge to see if the code re-appears?
2005 TD 3500, auto trans.
