I know T. Baker says all you need is 36". Tell us how tight that is. That requires an electric fan, right? Which side of the radiator did you put the fan? What kind of fan did you find to push enough air. I couldn't find (read as: afford) an electric fan powerful enough to cool my 5. 9 gas motor.
Does a tight fit like that cause other problems such as heat and noise transfer to the firewall?
What would be the ideal engine compartment size? How much room do you need to run the belt-driven fan? What is the length of the engine compartment of a Dodge truck?
I'm daydreaming about the much contemplated Cummins swap into a Power Wagon. I know a 4bt will fit. I even got to drive one recently. Noise and vibration seemed to be the only short-comings. I keep wondering about the 6bt. A while back I doctored a photo of my Carryall to see what it would look like with a longer snout.
I like the results. If I put my Carryall body on an ambulance frame (121" wheelbase), that would give me 7 more inches for a total of 37" between firewall and radiator. I could probably fabricate a superior radaitor and gain another inch or two. I estimate my doctored photo to actually be stretched 9 inches. You can see it has 4 pair of louvers in the hood instead fo three. If I were brave enough to cut the frame I suppose I could make it as long as I want.
Remeber, I'm just daydreaming. I've always admired the luxury cars of the 1930's with their long hoods-the same proportions you see in big trucks. The stylized magazine ads of the day exagerated those proportions even further. I always thought it would be cool to subtly alter a vehicle to look just like those vintage advertisements. The Power Wagon had some big brothers with proboscis like that. In fact the, styling of the civilian Power Wagons has been credited to the 3-ton Burma Dodges previously exported to the far east. Still, there's something to be admired about the practical stubbiness of the Power Wagon.
