Engine Cleaning Question
Jet Landing in Tranmission?
What Injectors to Get?
I want to clean my engine using a warm water pressure washer and don’t want to mess anything up. I know not to get water in the air intake, what else should I be careful about getting water in or on within the engine compartment?
Ramin, I cleaned the engine on my '03 a few times. I would avoid the alternator, the ECM, the injection pump, and any significant wiring harnesses. I would discourage using a pressure hose, I used a garden hose with sprayer hooked up to my hot water tank.
Vaughn
JHardwick said:
leave her runnin and hose her down!!!!
I don't know if that's a good idea, at least on a 24-valve that's a good way to quickly destroy a VP-44 :eek:
The CP3 may be more tolerant, but with the super close tolerances of the HP injection pump spraying cool water on a hot pump runs the risk of shrinking the external case slightly and cause it toseize up internally.
Vaughn
