Engine/Transmission (1994 - 1998) Engine Codes for 1995
Engine/Transmission (1998.5 - 2002) Bottle
Engine/Transmission (1994 - 1998) which FASS is for me?
Need help with Engine Code.
Key on, off, on ,off, on and I get this: | is Engine Light on and a space is Engine Light Off so this is what I saw this twice: | | || |||| | ||||| ||||| off
Your codes are a two digit number. Do the switch sequence, then count the flashes. There will be a 1. 5 second pause between numbers and a 2. 5 second pause between different codes. Looks like the last code you have there is a 55, which is the end of sequence code...
Here is a basic list of codes. .
PCM Fault Codes
good luck
-j
ToolManTimTaylor assembled the 24V code list in a 3/14/2004 post. I quickly checked it but found nothing that resembles what you list.
Sorry, maybe someone else could help.
Regards
