Engine Codes
another Oil change question (short)
Lube points
Does anybody know what these codes are? I read this with the Bully Dog Pup.
P3201
P1806
P0206 Fuel Injector 6
P337
do a search
P3201
P1806
P337
If you do a search you should find all the info you need. Were you running on e of the downloads when you set the codes?
I don't have P3201 or P1806 in my Powertrain Diagnostics Manual (PDM, 2003).
P0206 - Injector #6 Control Circuit
Set Condition: when the injector current falls below a calibrated threshold.
P0337 - Crankshaft position sensor voltage too low
Set Condition: voltage detected is below a calibrated value for a calibrated amount of time.
In my opinion, blame for these codes lies squarely upon any aftermarket fueling box you might be running. Try removing it and see if the codes go away. I don't think there's been any instances of anyone actually burning out any sensors or injectors as a result of using a fueling box. :)
-Ryan
LMcCary
If you have several areas in which you have low voltage,then you have something pulling down the regulated volts from your ECM. If your voltage is high to those areas, then you have lost ground to the ECM. Please recheck your wiring. If you don't find the problem, Disconnect the add on box.
