I have a 99 3500 Dually that runs great from an idle to about 55mph, but at 55-70 the engine will cut out as if you just took your foot off the gas pedal. The strange part to me is it won't do it all the time, I have gone 300 miles without an issue and other times it will cut out over and over in 50 miles. The engine never dies, it still runs just no power. It seems like it might be heat related, because if I pull over for a while it won't do it right away. If I put the truck in neutral when it does it and rev the engine a few times most of the time it will recover. When it does it, it does not throw any engine codes. My lift pump was replaced a couple of years ago, but I suspect it might be my issue.
Please help.
Thank you
Please help.
Thank you
