Engine diagram?
Rumor has it that......
Possible 1992 W250 up for grabs
Anybody know where to get an engine diagram for a '93 CTD? My buddies little brother smoked the oil pump on it, and then procedded to drive it a little farther... they're tearing it all the way down, but would like to know where everything goes at the same time.
Also, they need to know torque specs for most everything, ESPECIALLY the main bearing.
Thanks for any help.
Josh
I would suggest buying a service manual from the dealer. It has a very good break down with all the spec's you need. It took 4 days for mine to come in after I ordered it.
Philip
Engine Service Manual
What it is... ... technically speaking,it's the Troubleshooting and Repair Manual, B3. 9 and B5. 9 Bulletin No. 3666087-01 This is the one I use and purchased from the local Heavy Truck dealer,an authorized Cummins dealership, not through mopar. I don't go there for any Cummins related items:rolleyes:They just don't seem to know what it is... ... .....
bearing torque
snowracer69
The bearing torgues on your engine are in three stages, both connecting rod bearings and the main cap bolts as per following.
Main bearing bolts ( 3 stages) 45-88-129
Connecting rod bolts ( 3 stages ) 26-51 73
The above torgues are in foot lbs.
Chuck Goode
