OakViewJeff
My 99 24-valve suddenly lost all power and dropped to an idle while running at normal speed. Once at idle the power cam back with the Check Engine Light on. The light reset after about 5 restarts of the engine.
This is the second time in two weeks this has happened.
What can cause this? I did not know of the procedure to capture the codes (Key On-Off three times) while the light was on. Can the codes be captured after the light has gone off?
Thanks for any advice
OakView Jeff
OakView Jeff
