Well, since I'm stymied on doing the KDP until next weekend, I think I'll do a disable switch. Especially after see another stolen rig thread. So I have a question. According to the pics in the recent issue of TDR where Joe is installing a disable switch there is suppose to be a connector by the brake on the 89 where you put the switch. I looked and there is not one on my 97 in the same location.
However, there is a green connector mounted on the metal bracket under the clutch with wires running to a sleeve which surrounds the clutch activation rod. Is this the right place? Seems intuitively obvious--BUT I hate to do a stupid thing. Unfortunately I gave away the 98 12v shop manual and Chiltons when I sold my 98--yeesh!
Second ?. The engine identification number tab is missing off the timing cover on the 97. Is there an alternate location for a engine i. d. # ?
I've crawl all over and here is some #s I've scrounged up:
* Oil pan: 3925772
* Underneath the drivers side of the intake manifold or head, I forget now, sort of behind the P7100: 3253925400
* On the drivers side of the block there are the following in vertical format, versus horizontally, 3924606USA and then T4 below the USA
Are these useful and can anyone decipher the code? The engine ID will help when ordering parts (I've already encoutered that problem). Plus, the FUD gremlins have me convinced this is really an engine swapped out of an 89 with 777 miles on it and stuffed into a wrecked 97.
:-laf Actually, based on the wiring, hoses, harnesses, and etc. it doesn't look like the engine has been out of the truck.
* Oil pan: 3925772
