Would like to install a 'kill' switch to the fuel pump as a cheap theft deterrent device. This will also allow turning the engine over without it starting. On the 12v engines this was done by instaling the switch in the fuel shutdown solenoid wire from what I can remember. Heard and read that to do this same on the 24V requires taking the connector off of the engine computer and installing the switch there. Do not like the idea of this. First of all the area is tight and it would be real easy to slip and cut/nick another wire. There is also the matter of getting that connecter back on and torqued correctly. Over torque and need to replace more expensive parts.
Is there another place where this 'kill' switch can be installed?
