Engine/Transmission (1994 - 1998) engine miss after warm up
Engine/Transmission (1994 - 1998) Lost allen plug on AFC
Engine/Transmission (1998.5 - 2002) trouble codes
I have a 94 Dodge with 230,000 miles on it. My truck idles fine until it warms up and then it has an engine miss at idle that seems to clear up a little at higher RPM's. I can't tell if it's lost much power and there is no smoke coming out of the exhaust. It seemed to happen after I filled up at a local filling station so I checked for water in the system and changed the fuel filter and found no evidence of water. I replaced the injectors about 15,000 miles ago. Any ideas on what could be causing this? Thanks.
The early p-pumps have a history of sticking plungers after the engine gets warm. The next time it starts to miss, pour some cold water over the pump. If the miss goes away you need to get the pump fixed.
