Engine noise at 2000 RPM
hypertech
Mag Hytec Transmission Pan
I have a howling noise from my engine at 2000 RPM. Sounds like a window is open. It's only between 1950 RPM and 2050 RPM. Is that normal. Sounds like the turbo. 99 Dodge, Ram, 2500, Auto, Thanks, Bob B.
Pull the snorkle that connects the air cleaner box to the inner fender and no more howl plus the engine will breathe a little easier. it's easy, just grab and yank. Simple BOMB #ad
2001 HO 6 speed Regular Cab SLT 4x4 3. 54 anti spin 2500. Used for the daily grind and sneaking away to some secret Baja beaches toting a cabover
Do you think he's a candidate for the heater hose howl fix?
'99 2500 ISB QC SLT (No Leather!), 4x4, 5sp w/McLeod, 4:10, BD-II, PE, PE-EZ, 4"exh. , Pac-Brake, A-Pillar gauge pod w/boost and pyro, Line-X, V-1, lights, siren, lic. plt. frame says "Diesel Fumes Make Me Horny!", and much more goofy stuff.
Mine did the same thing took it to the dealer and they fixed it. Heater hose restriction on the fitting. Ron
1999, 3500, 6x6, slt, auto, 3. 54, Qd cab, ISB cummins, towing 2001 26RKSS Tahoe 5th wheel, 1999 120hp 1800 bayliner.
For the heater hose noise you can do one of two things. You can unscrew the "gold" hose fitting at the cylinder head and pull out the rubber grommet that's inside,or take it to the dealer and see if they will install the new "black" fitting under warranty.
-Mike
Mine groaned a little warming up after getting some fuel in South Georgia about a month back. When I left Melbourne, it was 75 deg. When I fueled up it was 25. The noise occured at about 1800 RPMs and the temp wasn't back to 190 yet. Thought it might be the heater. Hasn't done it again.
