Engine out of truck what should I do now
Amsoil single by pass users I have ?'s
Electronic copy of EZ user's guide?
I have my 1995 CTD w/nv4500 (was auto) out of the truck and on a pallet. The truck has only 130k miles and is going to get a few upgrades. I already have pyro and boost gauge and 5" exhaust installed. So here is the list of stuff I am buying from Piers:
370 injectors
4000 rp GSK w\ valve springs
?? cam plate (not sure, help)
overflow valve
ATS 3 piece manifold
16cm non-waste turbine housing
exhaust brake for 4" exhaust
5spd con o clutch
pump timing advanced 2 deg
some little valve thingy(forgot name)
KDP (for sure)
Should I also do the head gasket with a copper one while I have the engine out and maybe the cam?
Am I forgetting something else?
Any comments, since I am new to this power game?
I use this for towing my 10,000lbs trailer only not hotroddin' around, this CTD is going into my 1982 chev crewcab dually 4x4 with 11. 00R16 michelin XL tires
Should I step up and put a piers cam in since I have the motor out.
Any suggestions on what or what not to do while I have this motor out?
Thank you for your help in advance
ISH
Might as well do the cam & anything else you can think of/afford- it'll never be any easier to work on than now while it's out of the truck!
P. S. O-ring the head.
