RUSTJC: Re. heat verses compression. Chrysler has the grid heaters to warm the air on cold days which replaces the glow plugs. Compression makes the air heat. Lower compression makes an engine harder to start no heated air. Add ether and BANG! The fuel on a diesel is direct injection and is added at the time set up by the computer. The gas engine fires the injectors sometimes in pairs or etc. fuel is laying on the back of the valves waiting to go into the cylinders. Been reading the posts and lower compression requires lots and lots of fuel and boost pressure.
Chrysler lowered compression and retarded timing in an effort to meet emissions standards. No benefits to the diesel for improved fuel economy or power. My real question is what they did to lower compression, heads or pistons? On a gas engine the leaner the fuel mixture the higher the cylinder temps which accounts for high nox emissions. More fuel lowers cylinder temps.
Just some thoughts.
Just some thoughts.
