Today after driving about 100 miles, about 10 miles from home my truck died. It did not show any signs of running any different before it did it, no check engine light or nothing. Just fueled up about 60 miles up the road. I pulled up to a light and it just shut off. I have a fuel psi guage and everything seemed normal. I cracked the lines on the filter housing and she pumped clear fluid ( no air ). I unhooked the ez and still nothing. Called the wrecker and after waiting about 30 minutes I decided to try it again. It fired up and ran ruff but after about 3 minutes it cleared up. Reved up fine and seemed like all was good. I pulled it in gear and she cut off and would not crank again. Wrecker pulled me home. I went and picked up a new fuel filter thinking maybe dirty fuel. Filter looked clean with no signs of water. Changed it out bled all lines and finally she fired up. Running a little ruff at first but cleared up. I let it sit there and idle ( in neutral ) for about 10 minutes. Reved and ran fine in neutral. Cut it off and it would not crank. Finally fired up again and let it set and run 10 more minutes, pulled it in gear and it cut off. It's like there is no power there. I only have 51,000 miles on her and I have the extended warranty. I just wanted to make sure it was not something small that I could fix. Anyone have any ideas?
Thanks, Dion
Thanks, Dion
